010371: Observer at <value>, <value>, <value> is below surface <value>
The elevation of an observation point as specified in the SPOT attribute item is below the surrounding surface.
Solution
Specify an appropriate elevation value in the SPOT attribute item, or remove the SPOT item so that the elevation is computed internally from the input surface raster.
