010446: No valid statistics exist to set default parameters. Click the Calculate Stats button to obtain valid statistics.
The statistics necessary to calculate the default parameters for the function either do not exist or are no longer valid. Invalid statistics could result if you change the processing extent before the tool is opened or change it once the tool is opened and the input raster and function are selected. Certain function parameter fields may be empty.
Solution
Click the Calculate Stats button to see the default parameter values that will be used when the function is applied.
