010453: The GPU being used is controlled by the WDDM display driver. This may cause the computer to appear unresponsive. This driver may reboot the GPU if the computation takes too long.
This message appears when the tool is using the GPU connected to your display. This occurs when there is only one GPU on your computer.
Solution
This is a warning message and does not affect tool processing. However, the display performance is affected. You can install another GPU if you don't want the display performance to be affected.
For details on technical aspects of using GPUs with this tool, see GPU processing with Spatial Analyst.
