010508: Distance mapping will be significantly faster for very large rasters if the container process's token can be adjusted to include the SE_MANAGE_VOLUME_NAME (Perform volume maintenance tasks) privilege.
The Security Policy of the user account being used does not have the appropriate privilege to perform volume management on the system, which may lead to reduced performance.
The specific Windows authorization Privilege Constant is SE_MANAGE_VOLUME_NAME, which controls whether the account can perform volume maintenance tasks.
Solution
If the account does not have access to this privilege and if the tool process uses a temp file, performance may be affected.
Contact your system administrator regarding being granted permission to make the appropriate changes. Ensure that all changes are performed carefully and correctly, and consider making appropriate backups before making the changes. Esri assumes no responsibility in the configuration of the systems of end users.
