010568: Invalid extent. Please check for zero length or width, or failure to project extent to output spatial reference.
The processing extent for this analysis is invalid.
Solution
Set the Output Extent environment to the extent you want to process. If this does not resolve the error, make sure your dataset extents overlap. To confirm that your dataset extents overlap, project them into the same spatial reference.
