010581: The extent of the input surface will be used as the analysis extent. Is this intended?
The input surface extent is being used as the analysis extent. A large extent may result in longer processing time than expected.
Solution
If the analysis only requires a portion of the input raster, set the Extent environment to limit the processing to that area. This will reduce the overall processing time.
