010651: Input raster layer or dataset <value> does not exist.
The specified input layer or dataset in the criteria table cannot be found. The following are possible causes:
Layers with specific names in the criteria table were not added to the Contents pane.
Datasets were removed from their original path or the path specified in the loaded text file.
Text files with layer names were saved and used, while the specified layers were not added to the Contents pane.
Solution
Do any or all of the following:
Add raster datasets with specified names to the Contents pane or rename a layer to a specified name as shown in the criteria table.
Correct the paths of the datasets or the paths in the text file to the current location of the datasets to be used.
Replace layer names with their full paths in the loaded text file.
