010660: Cannot store integer cell values that are less than the minimum integer value of -999,999,999 in a TIF (dBase) raster attribute table.
All output values must be between -999,999,999 and 2,147,483,647.
For file-based rasters in TIFF format, the attribute table of the raster is saved in a dBase format in the same folder or at the same directory level as the raster, with a .vat.dbf extension. The largest value that can be stored in the attribute table in the signed 32-bit integer range is 2,147,483,647.
Solution
When the output format is TIFF (dBase), specify the appropriate parameters to ensure that all output values are between -999,999,999 and 2,147,483,647.
For the Slice tool, the parameters that affect the output values are Number of output zones, Starting value for output, Change NoData to value for output, and Interval size.
For the Reclassify tool, the output values are specified in the New column of the remap table.
