010661: The output values for Slice or Reclassify cannot be stored in an integer raster dataset.
The output values must be between -2,147,483,646 and 2,147,483,647 (the largest value range that a signed 32-bit integer field can hold).
Solution
Specify appropriate parameters to ensure that all output value ranges are between -2,147,483,646 and 2,147,483,647.
For the Slice tool, the parameters that affect the output values are Number of output zones, Starting value for output, Change NoData to value for output, and Interval size.
For the Reclassify tool, the output values are specified in the New column of the remap table.
