010778: <value> field type is currently not supported.
The input field is not a valid type for the operation. Operations often require a specific type of field.
Solution
Review the tool documentation for the valid field types. Ensure that the input is of the correct type.
You can use the Add Field tool to add a new attribute field; then use the Calculate Field tool to populate it with values.
