010784: The value of the Sun map H3 grid level is invalid for the Earth. The value must be within the range from 5 to 7.
The value specified for the Sun Map Grid Level parameter is invalid for input surface data on the Earth.
Grid levels affect the size of the hexagon grids used for sun map areas during analysis. Lower grid levels create larger sun map areas where the sun elevation and azimuth angles are used for the processing cells.
Solution
For analysis on the Earth's surface, specify a sun map grid level within the range of 5 to 7.
