010786: Insufficient memory available to process all regions.
The tool does not have enough available memory to process all of the input regions.
Solution
Try the following:
  • Reevaluate the input regions. If possible, simplify the regions or use fewer of them.
  • If the input region data type is feature, rasterize it in a preprocessing step and use that result as input to the tool.
  • Ensure that any regions outside the analysis extent are not submitted for processing.
  • Confirm that the output cell size is reasonable for the analysis. Refer to the tool documentation for additional guidance on setting an appropriate cell size.
  • If possible, don't perform other operations on a machine while it's processing large datasets.
