010792: The current settings will analyze only one scale.
The current settings for the Minimum Neighborhood Distance, Maximum Neighborhood Distance, Base Distance Increment, and Nonlinearity Factor parameters will result in only one scale being analyzed.
Solution
If this is intended, leave the settings as they are.
To run analysis on multiple scales, change the Minimum Neighborhood Distance, Maximum Neighborhood Distance, Base Distance Increment, and Nonlinearity Factor parameter values. You may need to increase the Maximum Neighborhood Distance parameter value or decrease the Base Distance Increment parameter value accordingly.
