010798: The current settings will analyze only one scale.
The current settings for the Minimum Neighborhood Distance, Maximum Neighborhood Distance, and Distance Increment parameters will only analyze one scale.
Solution
If this is intended, leave the settings as they are.
To run analysis on multiple scales, change the Minimum Neighborhood Distance, Maximum Neighborhood Distance, and Distance Increment parameter values so that multiple scales will be analyzed. You may need to increase the Maximum Neighborhood Distance parameter value or decrease the Distance Increment parameter value.
