010800: No depressions found meet the specified criteria. An empty raster will be output.
The Input Surface Raster parameter value does not contain depressions that meet the criteria set by the optional analysis parameters: Minimum Depth, Minimum Area, Maximum Distance to Connection, and Maximum Distance to Roads.
Solution
Adjust the settings of the optional analysis parameters and run the tool again.
Alternatively, run the tool with default values first; then adjust the parameter values as needed.
