010802: The GPU specified by the GPU ID environment setting is not available for use. The default will be used for computation.
The GPUs that are available for analysis are controlled by the CUDA_VISIBLE_DEVICES system environment variable. The specified value for the GPU ID environment setting is outside the domain of available GPUs.
Solution
Review the available GPUs on the machine and the CUDA_VISIBLE_DEVICES system environment variable. Specify a GPU ID parameter value that is within the list of available GPUs.
Learn more about GPU processing with Spatial Analyst.
