010811: To properly handle the edge of the projection at a global extent when performing distance analysis at a global scale, ensure that either a cylindrical projection or a geographic output coordinate system is used in conjunction with the geodesic method.
Analysis at a global extent needs to be performed in a cylindrical projection or a geographic coordinate system. In both cases, the geodesic distance method parameter must be used and the processing extent must span the whole world.
Solution
Specify the geodesic distance method parameter and set a global extent while using either a cylindrical projection or a geographic coordinate system.
