010814: To produce correct results, a geographic output coordinate system should only be used in conjunction with the geodesic method.
The Geodesic option in the Distance Method parameter should be specified when the output coordinate system is geographic. Using the Planar option with an output geodesic coordinate system will produce incorrect results.
Solution
Specify Geodesic for the Distance Method parameter when the output is a geographic coordinate system.
