010840: One or more output frequency values cannot be stored in the specified output table format. These values are returned as –9999.
One or more output frequency values exceed the range that can be stored in a field with the long (32-bit integer) field data type. The specified output table format does not support the big integer (64-bit integer) field data type to store these values. A value of -9999 is returned in the output table in place of these unsupported output frequency values.
Solution
Create the output table in a file geodatabase, where the field data type will be automatically converted to big integer when the output contains large integer values.
