030001: Parameter is not a network analysis layer or is a disconnected layer.
The path to the network dataset referenced by the network analysis layer is no longer valid.
Solution
Open the Layer Properties dialog box for the network analysis layer, click the Set Network Dataset button on the Source tab, and set the path to the correct network dataset.
