030020: Failed to generate directions.
The directions could not be generated for the input network analysis layer.
Solution
Ensure that all the edge sources in the network dataset have a valid value for the Name field in the Street Name Fields section in the Network Directions properties. If the input network analysis layer is a vehicle routing problem layer, ensure that the output shape type property is not set to None.
