030028: Could not find any edge feature sources with a field named <value> or the field types are not the same among the edge feature sources with this field name.
This may be due to the following:
Situation 1—The field specified in the Alternate ID Field Name parameter does not exist in the edge sources.
Situation 2—The edge sources have alternate ID fields with the same name but different field types.
Solution
Potential solutions are as follows:
Situation 1—Specify the correct field name.
Situation 2—Ensure that all edge feature sources referenced by turns have the same name and field type for the alternate ID field.
