030099: Default <value> language was used for directions because the specified language, <value>, was not found.
When generating directions, the specified directions language was not available, and the default directions language was used.
Solution
Ensure that the foreign language version of ArcGIS corresponding to the desired directions language is installed.
If the directions are to be generated on an ArcGIS server using a geoprocessing service, this message can be ignored if the server has the necessary foreign language version of ArcGIS installed and the machine on which the geoprocessing service is being authored does not have the necessary language version.
