030105: Network analysis layer uses hierarchy.
The requested operation is not supported because the specified network analysis layer has the hierarchy property value set to USE_HIERARCHY.
Solution
Change the properties of the input network analysis layer so that it does not use hierarchy, or create a new network analysis layer that does not use hierarchy, and specify the new layer as input.
