030106: Network analysis layer has output path shape equal to None.
The requested operation is not supported because the specified network analysis layer has the output path shape property value set to NO_LINES.
Solution
Change the properties of the input network analysis layer so that it uses other options for the output path shape property, or create a new network analysis layer, and specify the new layer as input.
