030129: Directions are not configured for this analysis layer.
The option to populate directions was enabled, but the network dataset on which the analysis was performed doesn't support directions. The output directions feature class is empty.
Solution
To generate directions, the network dataset on which the analysis is performed must have directions configured. You may be able to configure directions on the network dataset or solve the analysis on another dataset that has directions configured.
