030145: The distance between any inputs must be less than <value> miles (<value> kilometers) when walking.
The tool failed because the maximum straight line distance between the inputs when performing an analysis using a time-based or distance-based walking travel mode was exceeded.
Solution
Reduce the extent covering the inputs or run the analysis using a travel mode that is not based on walking.
