030167: The attribute name, <value>, used with parameter name, <value>, is not valid.
When specifying attribute parameter values, the combination of the attribute name and the parameter name needs to be valid for them to be applied to the analysis. For example, the attribute name should be an attribute that exists on the network dataset, and the parameter name should be associated with the specified network dataset attribute. Invalid combinations are ignored while performing the analysis.
Solution
Specify a valid combination of the attribute name and the parameter name.
