030196: <value> and <value> parameters should have the same values.
When using a custom travel mode, if the impedance attribute is time based, the value for the time attribute and the impedance attribute must be the same, and if the impedance attribute is distance based, the value for the distance attribute and the impedance attribute must be the same.
Solution
Specify a valid combination of impedance attribute and time attribute or impedance attribute and distance attribute.
