030233: A VRP Layer can have only one type of breaks: time window breaks, maximum travel time breaks, or maximum work time breaks.
Multiple types of breaks are specified for the route in a vehicle routing problem analysis layer. The Breaks class supports only one type of breaks in a layer: Time Window Breaks, Maximum Travel Time Breaks, or Maximum Work Time Breaks.
Solution
Ensure that only one type of break is specified. If the vehicle routing problem analysis layer Breaks class already contains breaks of a different type than you are trying to add, you can manually delete them or uncheck the Append To Existing Breaks parameter when running the Add Fleet Routing Breaks tool.
