030237: <value> can only have 5 breaks.
In a Vehicle Routing Problem layer, a route can have a maximum of five breaks.
Solution
Ensure that there are no more than five breaks for each route in a Vehicle Routing Problem analysis layer.
When running the Add Fleet Routing Breaks tool, do not specify more than five breaks to add.
If the Vehicle Routing Problem analysis layer already has breaks for the route to which you are trying to add breaks, delete some breaks manually or uncheck the Append To Existing Breaks parameter when running the tool so that the total number of breaks for the route does not exceed the limit.
