030303: Directions are only supported when populating route lines.
When a vehicle routing problem analysis layer is created referencing the vehicle routing problem service published from ArcMap, directions cannot be generated when the layer's output geometry is set to No Lines.
Solution
  • If you don't need directions output, uncheck Output on Solve in the Directions group on the vehicle routing problem analysis layer's ribbon.
  • If you need directions output, choose the Along Network option in the Output Geometry drop-down list on the vehicle routing problem analysis layer's ribbon.
