030305: Failed to set property <value> from solver config file. The solver's default will be used instead.
When configuring network analysis, the tool uses a solver settings defined in a config file. This warning occurs when the config file includes an invalid setting or value. In this case, the config file setting will be ignored, and the solver's default value for this setting will be used.
Solution
You can ignore this warning and accept the solver's default value, or you can update the config file to include only valid settings and values.
