030326: The <value> parameter is not supported on the portal used as the network data source for this layer and will be ignored.
The network analysis layer uses a routing service as its network data source. A nondefault value was specified for a parameter that is not supported by that service. That parameter value will be ignored.
Solution
Ignore the warning, use a different network data source for the analysis, or do not specify a value for this parameter.
