030396: The solve operation could not be completed because the routing service timed out.
The routing service used by the solve operation took longer than the maximum time allowed by the service administrator.
Solution
If possible, break the inputs into smaller chunks. This can help decrease the processing time and allow the analysis to complete within the allowed time frame.
  • If you are using a routing service from ArcGIS Enterprise, consult with your ArcGIS Enterprise administrator. They may be able to configure the usage timeout on the routing service to a higher value.
  • If you are using a routing service from ArcGIS Online contact Esri Technical Support for assistance.
