040101: At least one part of zone <value> is located outside the simulated rasters. Statistics for this zone will not be calculated.
At least one part of a polygon area of interest falls outside the simulated rasters' extent. As the polygon contains raster cells with values = NODATA, statistics cannot be calculated for the polygon.
Solution
Adjust the polygon or extend the rasters' extent so the polygon will fall within the extent of the simulated values.
