040205: At least one subset extends further than <value> in your geographic units. Reliable predictions cannot be calculated.
At least one subset extends beyond 30 decimal degrees (or equivalent geographic units).
Solution
You can avoid this error by using any of the following semivariogram models:
  • Power
  • Linear
  • Exponential
  • Whittle
  • K-Bessel
If you need to use a semivariogram model that is not listed above, you may be able to avoid this error by reducing the value of the Maximum number of points in each local model parameter.
