045060: The minimum number of points per subset cannot be greater than the maximum number of points per subset.
The value of the Minimum number of points per subset parameter cannot be larger than the value of the Maximum number of points per subset parameter.
Solution
Change the values of minimum and maximum number of points per subset so that the minimum is not greater than the maximum.
