045061: The elevation units parameter must match the Z-unit of the vertical coordinate system of the input features if Shape.Z is used for the elevation field.
If Shape.Z is specified for the Elevation field parameter, the Elevation field units parameter value must match the unit of the vertical coordinate system.
Solution
Verify that the Elevation field units parameter value matches the unit of the vertical coordinate system. You can also leave the units empty, and the unit will be matched automatically.
