045073: There were ties for the model with highest rank.
At least two models tied for the highest rank. The ranks of each model are saved in the output table of the tool.
Solution
No action is required. However, consider adjusting the parameters of the tool so that only a single model has the highest rank. If you are using weighted average rank, adjust the criteria and weights. If you are using hierarchical sorting with tolerances, reduce the tolerance values of the criteria, especially the final criterion in the hierarchy.
