050015: Error extracting TIN from Terrain.
The TIN extraction function failed because the TIN was too large to be supported by the system's memory resources, or there was insufficient disk space to store the resulting TIN.
Solution
The combination of area of interest and pyramid level settings may result in a TIN that's too large. Try extracting a smaller extent area or a coarser terrain pyramid level, or decreasing the value of the maximum number of nodes parameter. Also, check that the output location is write enabled with sufficient free disk space.
