050043: Point feature layer does not have 3D symbols.
To produce output, this tool needs the appropriate layer properties set such that what gets rendered in 3D can be represented using multipatches. In the case of point input, this means they must be assigned 3D symbols. None were found.
Solution
From the Symbology tab of the point layer, select 3D symbols to draw the points.
