050075: A window size pyramid type is not supported by this release of the geodatabase.
The target database chosen does not support a window size pyramid type.
Solution
Versions of ArcGIS prior to ArcGIS 9.3 do not support a window size pyramid type. Check the version that the database was created in. If necessary, upgrade the geodatabase to a version that supports a window size pyramid type.
