050106: Too many points have been chosen to build a TIN. Either increase the amount of thinning or increase the maximum allowed output size.
The number of LAS dataset points used in creating the TIN exceeds the maximum number of nodes supported by the TIN. This limit depends on the availability of contiguous memory resources, and it typically ranges from 10 to 15 million data nodes on 32-bit operating systems.
Solution
Reduce the number of LAS data points being used to create the TIN by thinning the number of points.
