050131: Both GPS Time Types (Weekly Time and Standard Time) were found in the input LAS files. The values of only one GPS Time Type were kept (the GPS Time Type of the LAS file whose file index is 0 in the LAS dataset); the values of the other GPS Time Type were changed to 0.
The LAS format only supports storing GPS times in one format. The GPS time type found in the first .las file will be used for all output .las files. Any .las file containing a different GPS time format will be assigned a value of 0.
Solution
Consider separating .las files by their associated GPS time type to avoid conflict.
