050160: The specified GPU does not exist or is not supported.
Either the specified GPU ID does not correspond with a GPU on the machine or the GPU does not satisfy the minimum requirements for executing the tool. An NVIDIA graphics card that supports CUDA and has at least 2 GB of memory is needed for this operation.
Solution
Ensure that an existing GPU ID is specified. If the computer only has 1 GPU, the ID will be 0. If the GPU does not support CUDA or have at least 2 GB of memory, set the Processor Type environment setting to use the CPU.
