050186: The Base Visibility Angle must be at least -90 and no more than 90.
The specified value for visibility angle exceeds the acceptable range. The limit is defined by 90°, which denotes a trajectory that is directly going up along the z-axis, and -90° which denotes a trajectory that is directly going down along the z-axis.
Solution
Modify the angle so that its value is no less than -90° and no greater than 90°.
