050211: One or more LAS files referenced by <value> were skipped because of broken paths
The LAS dataset referenced one or more .las files with broken paths.
Solution
Replace the .las files that have broken paths. To do this, first remove those files from the LAS dataset using the Remove Files From LAS Dataset tool; then add them from the correct location using the Add Files To LAS Dataset tool.
