050213: Training data's maximum point limit (<value> points) is lower than the minimum required for the selected architecture (<value> points).
The maximum point limit specified for creating the training data is lower than the minimum number of points that must be provided for each block. Each model architecture requires a minimum number of points.
Solution
Use an architecture that requires fewer points, or modify the maximum point limit to be equal to or greater than the minimum value required for the existing architecture.
