050217: Input data has coordinates that are not compatible with its coordinate system.
The coordinates in the input dataset are outside the range of values supported by its coordinate system. This usually indicates that either the coordinates are not properly georeferenced or they were originally assigned to another spatial reference system.
Solution
Determine whether the dataset is not georeferenced or if the wrong coordinate system is assigned. If the wrong coordinate system is assigned, use the Define Projection tool to assign the correct one and ensure that the data displays in the intended location when loaded in a map or scene.
